Static IP address reveals my name
Funk
I recently enabled static IP on my account and an IP address check now shows my full name as the hostname eg. {myname}.plus.com.
Please can this be anonymised?  It's not information I want publicly attached to my static IP. I tried the online chat (not live) and resorted to a call to tech support (voicemail)...
7 REPLIES 7
Fixes: 1,467
Re: Static IP address reveals my name
Moderators Note
This topic has been moved from Fibre to Everything Else
Fixes: 1,467
Yes it can be, you’ll just need to wait for a staff member to pick it up.
edwh
There's a wizard in the Help Assistant to request this - log in to your account then go to https://www.plus.net/wizard/?p=wizard&page=22425&wizard_id=38
The narrative says:
Changing Reverse DNS configuration
We can change your reverse DNS if you wish;
Alternative Reverse DNS options
The available rDNS configurations are:
username.plus.com (Default setting)
your-static-ip.plus.com (ie 212-159-0-2.plus.com)
any-host-name.domain.co.uk*
domain.co.uk*
There's a small freeform entry box further down the page to request your choice then click the "Send your question" button to submit it.
When I did it I seem to remember it took a day or maybe two to process.
Tibzor
Fixes: 25
Hi @Funk
Thanks for getting in touch and sorry for answer you have received on this ticket.
I will raise task to change that for you.
Funk
Thanks Tibzor; I'm not sure whether I do need to go in and do something through the wizard or leave it to your technical team?
In terms of format I'd be happy with {My static IP}.plus.com; let me know if there's anything I need to do my end or leave it with you...
Tibzor
Fixes: 25
Thanks for getting back in touch @Funk
Task was already raised by me yesterday so you don't need to raise ticket through wizard or do anything else.
Once I will receive confirmation that task was completed I will send you a message.
Funk
Cheers, all updated, anonymity restored!
