Static IP PTR reverse DNS
kevinjb
I now have a static IP on my Plusnet Broadband connection. At the moment the reverse DNS PTR record for my static IP is my "accountname".plus.com. Which is not ideal from an GDPR point of view. Also as I plan to run my own email server on the static IP ideally need the PTR record to point to FQDN of my mail server hosted on the static IP.
Is it possible to have the PTR reverse DNS record for my plusnet static IP point to an A record in my own personal domain.
Kind Regards
Kev
8 REPLIES 8
Fixes: 480
Re: Static IP PTR reverse DNS
Moderator's note:
Thread moved from Broadband to Everything Else.
kevinjb
Any PN staff on the forum that can help. I called PN support desk and unfortunately they were notable to assist.
Is it possible:
1. To have the rDNS of my static IP be something other than accountname.plus.com
2. Have the rDNS for my static IP point to a FQDN on my personal domain such as smpt1.mydomain.com
Kind Regards
Kevin
adamwalker
Fixes: 223
Hi Kevin, I can sort that for you. You'll just need to make sure you have the appropriate "forward" DNS record in place first, please let me know when that's done and we'll do the rest.
 Adam Walker
kevinjb
Thanks Adam, I have the forward DNS setup already for my static IP. Is there anyway I can PM you the forward DNS A record.
Kind Regards
Kevin
Fixes: 586
@kevinjb click on Adams forum name (in Purple) , that should bring up his profile page. On the rhs you should see a Send Private Message icon
kevinjb
Thanks MisterW, just sent a PM through to Adam.
Kind Regards
Kev
MatthewWheeler
Fixes: 503
Hi @kevinjb
We've raised the request for you now and this should be done in the next few days
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
kevinjb
Hi @MatthewWheeler that's great news, thank you and the PN team for the help with this.
Kind Regards
Kev
