Static IP PTR record
rob-spencer
Hi @adamwalker ,
I have seen a few posts about setting up a PTR dns record for enabling running an email server with a static IP. I have been running an email server at home for years, but recently have been getting emails bounced by some senders and it looks like I need this set up for me. Would you be able to assist?
Kind regards,
Rob.
Tags (2)
8 REPLIES 8
rob-spencer
Re: Static IP PTR record
The required server name is [Removed] for IP address 81*.*.*
Thanks,
Rob
Moderators Note: Personal information removed
Windings
Fixes: 14
Hey @rob-spencer,
I have sent you an email to the email address associated with your plusnet account regarding the request you have raised to us.
Joe Elliott
rob-spencer
Hi @Windings ,
Has there been any updates on this? A support question was raised on the 11/12 with an ETA of 7 working days, but it has gone quiet since then. Has the holidays slowed things down?
Cheers,
Rob.
Tina11192
Fixes: 18
Hey there @rob-spencer I tried calling you, however, I was able to only leave a voicemail.
I'm sorry to see that the task has not been completed yet and had to get back in touch. I have just had a look with @Windings and the task was rejected because there are no PTR records set up yet.
In order for us to change the PTR records, you need to set it up on your side first on the dedicated server that you are using, please ensure the A record is set up first and that is pointing to the static IP, once this is done, we will be able to re-raise it with our NetOps team.
Please let me know once that's done and I'll do the rest!
Cri Ignatti
rob-spencer
Thanks for the quick reply - sorry I missed your call. I'll look into getting this sorted out and then reply here once done,
Cheers,
Rob.
Tina11192
Fixes: 18
Hi @rob-spencer thank you for your reply, please be aware that after 6pm I will be out of the office, however, one of my colleague will pick up your reply at the earliest possibility.
Cri Ignatti
rob-spencer
Hi @Tina11192 / @Windings ,
An A record currently exists for my domain (mail.rob-spencer.com) which points to my static IP. Is there anything else I need to add to my DNS configuration?
Looking at similar requests that is all that seemed to be required.
Cheers,
Rob.
Marsh
Fixes: 41
Hey @rob-spencer,
I believe that should be sufficient. I have raised a request to get the changes actioned. Once I receive an update, I will be in touch. I have also opened a ticket on your account where I will keep you updated.
Josh
