Sogea line and VoIP.
djh22
Fixes: 5
I've got an extremely good deal with Plusnet by changing to  Sogea broadband but as a trade off have lost my landline, so is there anyway I can get VoIP on a Plusnet  Sogea line and can I plug my Dect phone into the socket of the Plusnet smart hub 2 ?
Thanks,
Del.
10 REPLIES 10
Fixes: 573
Re: Sogea line and VoIP.
The phone socket on the Hub 2 is not functional.
You can get a voip account from a third party voip supplier , but you would need an ATA (Analogue telephone adapter) such as https://www.amazon.co.uk/Grandstream-HT-812-2FXS-Gateway-Black/dp/B01M2ZJQAF/ref=asc_df_B01M2ZJQAF to connect your DECT phone
Fixes: 111
@djh22
Unless the change happened in the last 30 days you've lost your phone number.
A&A seem to offer a good deal and service.
https://www.aa.net.uk/voice-and-mobile/voip-information/
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to Everything Else
djh22
Fixes: 5
Thanks Brian, yes that is understood.
djh22
Fixes: 5
Thanks again Brian, this time for the link.
djh22
Fixes: 5
Thanks Dvorak, I wasn't sure where to post and I knew you'd move it if I was wrong 😀.
djh22
Fixes: 5
Thanks MisterW for the excellent advice.
djh22
Fixes: 5
I think I've decided on VoIP from aa,net and buying the Yealink w60b from them as they say it comes pre configured by them so hopefully it'll be plug and play but will I have to configure anything on the Plusnet smart hub 2 ?
Fixes: 573
In a word, no!.
djh22
Fixes: 5
Excellent thanks.
