Sky Go buffering on PS4
tcj1971
As the thread title says
Having lots of trouble with TV from Sky App on the PS4 as it is always buffering with the spinning circle
The TV from Sky App works fine on our Desktop PC and mobile AND on our old PS3
Is there any solution? I have tried uninstalling and re-installing the App but makes no diifference
Our internet is Plusnet Fibre with around 75mb Down and 20 Up
3 REPLIES 3
spraxyt
Aspiring Legend
Fixes: 75
Re: Sky Go buffering on PS4
This appears to be a problem common to many ISPs include Sky. No specific solution but you could try changing the PS4 DNS servers to Google's 8.8.4.4 and 8.8.8.8 (then restarting the PS4).
David
tcj1971
Thanks for the reply
Is 8.8.4.4     8.8.8.8 the right way round for Google and not 8.8.8.8    8.8.4.4
spraxyt
Aspiring Legend
Fixes: 75
It doesn't matter which of those you choose for primary and secondary. I tend to put 8.8.4.4 first since 8.8.8.8 is commonly quoted first. I expect Google keep a check on how the pair perform.
David
