Site dead!
- Everything else
- Site dead!
Site dead!
15-03-2010 6:08 PM
Arrghhhh. After the recent rebuild, the site at http://www.synergyconnections.co.uk is dead!
It's based on a CMS we did not create ourselves. Anyone see if these is an obvious fix?!
Message 1 of 3
(742 Views)
2 REPLIES 2
Re: Site dead!
15-03-2010 7:20 PM
Seems to be loading the page OK, it's whatever it's calling that's not working. First thing I'd check is your file permissions taking the advice here into consideration. I'd have a quick look myself but it doesn't look like your password matches the one for your main account.
If you get really stuck then raise a support ticket on your account following the guidance I offered another customer here.
Message 2 of 3
(168 Views)
Re: Site dead!
17-03-2010 12:03 PM
Quote from: GooKing Arrghhhh. After the recent rebuild, the site at http://www.synergyconnections.co.uk is dead!
Now sorted - it was two issues, one with the full path to the files being slightly changed, and one with permissions needing changed on some cgi files.
Message 3 of 3
(168 Views)
