Simulate internet disconnection
b1ink3r3d
Hello,
I am in the process of configuring a failover of a 4G connection on my home router. Would one of the plusnet team able to simulate a disconnection of plusnet internet if I ring their support department?
4 REPLIES 4
Fixes: 582
Re: Simulate internet disconnection
Can't you just either disconnect the PPPoE connection on the router UI or if that's not possible then physically disconnect the DSl/Ethernet cable ?
RealAleMadrid
Fixes: 68
@b1ink3r3d  No need to involve Plusnet, just do it yourself, pull out your phoneline connection to the router if on FTTC or the ethernet connection to the ONT if on FTTP.😁
RobPN
Fixes: 15
@b1ink3r3d
Couldn't you just 'pull the plug'?
Edit: MisterW and RealAleMadrid type faster than me.
@b1ink3r3d
They might be able to simulate a disconnection for you to test - but there is no guarantee that they will be able to restore it again once you have finished testing!
Much better to just pull a plug out yourself, as others have already said.
