Simple blog site recommendation?
- Everything else
- Simple blog site recommendation?
03-11-2015 2:59 PM
I dont have cgi space - just standard webspace.
I was going to have a bit of a play with a blog - but it looks like my choices are a bit limited (Wordpress/Joomla!, Drupal cannot install, Ghost needs node.js).
Anyone recommend a nice tool suite? Is it a case of roll your own pages only?
Message 1 of 3
(1,285 Views)
2 REPLIES 2
Re: Simple blog site recommendation?
03-11-2015 3:18 PM
Standard webspace is suitable only for static HTML pages. Support for dynamic content using CGI is essential for updating a blog.
If your aim is simply to experiment you might consider the free facilities offered by WordPress.com (https://wordpress.com/).
David
Message 2 of 3
(241 Views)
04-11-2015 12:51 PM
I was thinking of something more like the ones here :-
https://www.staticgen.com/
I'm having a quick go with Hugo at the moment. Local server is ok, but the themes dont seem to transfer into the static pages.
Might try Hexo next.
Message 3 of 3
(241 Views)
- Everything else
