Should I come to plusnet?
Greendore
Hello, I game online and my contract with virgin is up, the download speeds are brilliant but the ping spikes and packet loss make me not want to renew, whats plus net like for online gaming? Would anyone recommend them? I'm looking at the 74mb unlimited fibre deal.
20 REPLIES 20
rongtw
Fixes: 12
Re: Should I come to plusnet?
Hi , @Greendore  yes i can say Gaming with Plusnet is fine Thumbs_Up  i have 80/20  apart from a few hickups all is good , and i have been here 8 years Wink
Fixes: 418
Welcome to the forum.
I fear that the answer is akin to "how long is a piece of string". Plusnet is part of BT and use their infrastructure. How good your connection will be is dependent on your local infrastructure, the number of users on your fibre cabinet and upstream equipment etc.
Mustrum
Fixes: 77
@Greendore If you put your address in the DSL Checker, you will get a better idea of the speeds you are likely to get - ultimately your speeds will depend on how far away you are from your cabinet.
Greendore
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+ Up to 6 -- 4 to 8 Available
ADSL Max Up to 5 -- 3.5 to 7.5 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings       Availability Date
ADSL Multicast -- -- -- Available
No idea if thats any good!
Fixes: 418
No it's dreadful. Is there no fibre offering? What speeds are you currently getting?
rongtw
Fixes: 12
Oh dear thats not so good Shocked
Greendore
When I was with BT infinity i was getting 78mb down and I can't remember what my upload rate was. Atm with virgin im getting 240 down 25 up
ITWorks
Fixes: 9
With the info you have posted from DSL checker suggest fibre is not available to you.
What does it say here  when you put your postcode in.
You could always start the PN sign up online to see if it offers you fibre.
I have PN 80/20 have no problems with gaming.
paul30
hi there I've just seen your message on the forum I've had no problems in the past it's just lately I've had trouble with low bandwidth but I don't no if it's with the snow or not ?
andytay
Hi and welcome to the forum.
I recommend Plusnet because they are a helpful bunch especially on this forum.
I have been with plusnet for nearly 4 years and like a few others i have had issues but plusnet has always resolved them.
Hope this helps!
Greendore
"Great news, Superfast fibre is in your area."
I know I have fibre as I use to have BT infinity fibre Smiley I dont understand why that website thinks I dont have it.
Fixes: 1,600
@Greendore
If you can send me a PM with your address I'll be happy to take a look at this for you.
rongtw
Fixes: 12
@Gandalf  its 22.39 Thumbs_Up
Fixes: 1,600
It's actually 22:40. Cheesy
