Setting up website with word press
- Everything else
- Setting up website with word press
19-02-2013 4:24 PM
Hi all
Sorry if this has already been answered somewhere along the line but i would like to start using word press for my website creation and was wondering if anyone could give me a helping hand on how to point word press in the right direction so its using my full .co.uk web domain any help and advise would be grateful
Message 1 of 8
(2,150 Views)
7 REPLIES 7
Re: Setting up website with word press
19-02-2013 5:03 PM
It has been asked before, and this should hopefully cover what you need to know.
Message 2 of 8
(721 Views)
19-02-2013 5:20 PM
So if i follow the steps then point it to a .co.uk domain then it will work am i right in presuming this ?
Message 3 of 8
(721 Views)
19-02-2013 5:34 PM
If you follow the right steps to achieve what you want, yes.
Which steps to follow depends on whether you're mapping the full domain, a subdomain, or hosting it yourself.
Message 4 of 8
(721 Views)
19-02-2013 5:36 PM
I'd like to map the full domain so i am able to update with word press when required if you be able to take me through the steps it be much appreciated
Message 5 of 8
(721 Views)
19-02-2013 5:59 PM
Where is the domain registered, and do they allow you to modify the domains nameserver settings? (If Plusnet, no)
If not, you can't map the full domain.
The instructions on how to achieve it were in the other thread.
Message 6 of 8
(721 Views)
19-02-2013 6:02 PM
Yes Plusnet are hosting it so will this mean ill have to do it as a sub domain then
Message 7 of 8
(721 Views)
19-02-2013 7:04 PM
Unless you transfer domain registration away from Plusnet it will have to be done as a subdomain.
David
Message 8 of 8
(721 Views)
- Everything else
