Setting up Wordpress
- Everything else
- Setting up Wordpress
26-10-2009 2:24 PM
Ok, I've had a search through the forums and found a few articles on setting up Wordpress, one of them in particular seemed to cover everything perfectly, however it mentioned accessing the CCGI server via telnet to run a command (fixphpperms.sh -c) to enable PHP scripting to run, but of course, Telnet is disabled whilst the work continues on the CGI servers. I've found that I can't run the install.php script on my website and I have naturally assumed this was due to me not being able to run the command to allow php scripting to run on my sites, am I correct in this assumption and I'll just have to wait until the work is finished or should I be able to do this anyway wihtout the command (or is it possible via another method)? I just don't want to put this down to the CGI server issues when all the while I could be resolving the real cause of my problems.
Message 1 of 3
(807 Views)
2 REPLIES 2
Re: Setting up Wordpress
26-10-2009 3:37 PM
It is possible to fix your permissions, either using your ftp client or by a using a simple script. However, it would (IMHO) be prudent to wait for the new platform, if you can.
Gabe
Gabe
Message 2 of 3
(202 Views)
26-10-2009 11:10 PM
Using the FireFTP extension to Firefox to bulk-modify file permissions is described in this post by Bob Pullen. I can confirm it works.
David
David
David
Message 3 of 3
(202 Views)
