Service Status not accesible
OldRuby
ESet anti-virus Reports that the certificate of this website has been revoked and blocks access to it.
14 REPLIES 14
Fixes: 392
Re: Service Status not accesible
Do they give further details - like certificate owner/issuer/valid dates?
Fixes: 392
@OldRuby On further checking, I see what you mean. Maybe  @JonoH could help us?
If it helps, this is the resulting page detail:
Secure Connection Failed
An error occurred during a connection to plusnet.servicestatus.net. Peer’s Certificate has been revoked.
Error code: SEC_ERROR_REVOKED_CERTIFICATE
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem.
OldRuby
All it says is
The certificate used by this server has been marked as untrustworthy and the connection is not safe.
  Try connecting again later or from a different internet connection.
Fixes: 392
@OldRuby I can't remember all the details, but I looked fairly deeply into the certificate status, and it appears to have been cancelled - in error or not, and by whom, I don't know. Which is why I tagged JonoH.
seebee
Fixes: 9
Fixes: 392
Cheers, @seebee . I may be wrong, but I wonder if it has anything to do with the 'simplification' of the PN website?
bobpullen
Fixes: 331
Does look like the cert (or at least one of the certs in the trust chain) has been revoked.
I've raised it internally for somebody to take a look (ref: IMT-8160).
Fixes: 392
Thanks, Bob.
bobpullen
Fixes: 331
Should be sorted now.
Fixes: 392
It is, Bob - or at least it was just before lunch. 😀
OldRuby
Yes, now working here.  Thanks all.
Chilternphil
As of now 15:10 28/2/23 the service status page is unavailable - it times out.  I tried accessing from the community service announcement page button and (ironically) that too timed out. Link being used is https://plusnet.servicestatus.net › plusnet › status  with the result <An error occurred during a connection to plusnet.servicestatus.net.>
I tried from an Android tablet and same result.  Since the service obviously is working, has yet another problem raised its head?  I don't often need to use this page, but when troubleshooting its good to know if its you or me (normally me).
Fixes: 392
@Chilternphil Looks like that link is 'having trouble'. The best bet if you are having an issue is to raise it on the relevant board, where either staff or other Community members will pick it up.
MatthewWheeler
Fixes: 503
Thanks, @Chilternphil
We're aware there's an issue and we're working on a resolution.
No estimated fix time just yet but I'll post here as soon as I know more
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
