Samsung Galaxy Tablet- compatible with HSBC Mobile banking app?
Gel
Champion
Fixes: 29
As in subject line, does the PLAY STORE allow HSBC Mobile Banking App to be installed?
I predominantly use 2 Dell Laptops, but my pad is an Amazon Fire one, few years old;
PLAYSTORE annoyingly doesn't allow the HSBC App to be d/loaded onto it.
Or does someone with a recent FIRE tablet know if it can be installed on that type?
Thanks Smiley
3 REPLIES 3
Fixes: 580
Re: Samsung Galaxy Tablet- compatible with HSBC Mobile banking app?
@Gel if have a Galaxy Tab A running Android 12 and a Lenovo P11 running Android 13.
Play Store is giving me the option to install on both devices.
Gel
Champion
Fixes: 29
RobPN
Fixes: 15
@Gel
It depends on how new the Galaxy Tab is, or more specifically the version of Android.
First Direct (a division of HSBC) recently withdrew support for running their app on older versions of Android by requiring the latest version of the app to be installed, something which is not possible on those older OS versions.
My phone is still running Android 8 which now means I can no longer use the app, although I'm not sure if that's the cutoff OS version level.
