Samsung / Android Mobile Phone Firmware Updates Are Failing ?!
Re: Can't reach Android update server
Mine is on 209 range, does not work.
Fixes: 4
Still on the 146 range and the update server is working for me tonight.
Interestingly my phone now works!
Mine connected OK last night and applied the Sep 1 security patch with no problems
Fixes: 63
Thanks for your posts.
Was everyone now able to run the updates, or was anyone still experiencing issues?
@protos22 - I can see that on Saturday you mentioned that you could not download your update - is this still the case?
All good now, thanks.
All good here as well, thanks.
Fixes: 863
Excellent. Thanks for the confirmation.
Let us know if any further issues arise
I am having the same problem with Galaxy a50. Only way it seems to take any updates is when connected via its lightning cable to a PC, through smart switch. However the connectivity issue to android update server still needs resolved. Any fixes or remedies yet? Thank you all!:)
-Nicholas-
Fixes: 4
The problem was fixed and as far as I know, hasn't come back. I just checked my S10 and my works A50 both of them connected.
I still get the same error message when trying to check OTA. This is quite irritating. What all fixes do you know of? Any suggestions would be greatly appreciated
Fixes: 332
Thanks for getting in touch @nplewis
I'm afraid I can't find your accounts through the usual means.
Can you drop me a PM with the username so we can look into this for you?
 Matthew Wheeler
