Safeguard not working?
Re: Safeguard not working?
@pivo
You need to go to >Advanced Settings >Broadband
Click on 'Disconnect' and correct the Broadband Username to yours, the password is the same as the members centre, then 'Connect'
@MisterW
looks like the Hub is not associated correctly to this account
Fixes: 580
looks like to Hub is not associated correctly to this account
It certainly does! I'll try tagging one of the Help team to investigate... (if that doesnt work I'll escalate it)
@Marsh can you check this please ?
pivo
Thank you MisterW and Dan the van Safeguard is now working on my account!
Guess it proves that they do reuse hubs when they are returned - I always thought they put them straight in the bin.
Fixes: 580
Even so, they should be correctly associated with the account. The dispatch procedure scans the barcode and updates the account with the router serial no. When installed, the router then connects using the factory reset details and retrieves the correct username details.
