Safeguard not working on iphone
Apollo95
Safeguard turned on and works fime on my MacBook over wifi but not on my iPhone which is connected via wifi.Any suggestions?
4 REPLIES 4
Fixes: 580
Re: Safeguard not working on iphone
Is your iphone set tu se SecureDNS ?
The Safeguard system operates by assigning a different set of DNS servers to your router. If the iphone is set for secureDNS then it will be overriding the Plusnet supplied ones and so Safeguard will not work.
Apollo95
Thanks for reply. Set on Automatic.  No option to change any security. Tried on manual, still doesnt work. Deleted exisitng DNS servers.
Fixes: 1,495
Have you got Private Relay switched on?
Apollo95
No, its off
