Safeguard not working! Still not fixed after 4+ years!
- Everything else
- Re: Safeguard not working! Still not fixed after 4...
a week ago
Why is this still an issue after years and years??? Pretty discusted with plusnet now. And don't tell me to switch it on and off again. Nothing works and I can't even change the dns settings as the router you supply doesn't allow it!! Unbelievable.
Re: Safeguard not working! Still not fixed after 4+ years!
a week ago
Primary 212.159.13.49
Secondary 212.159.13.50
Which are the standard settings, not safeguard settings. So it's not switching over, even though I have toggles it on/off now several times etc.
a week ago
I also notice that there is no actual direct link to get to the safeguard page, I have to search Google to get there. I used to be under the members section but has now been removed, presumably because it doesn't work!! So why do you advertise it as something that can actually be used?
a week ago
Moderators Note
This topic has been moved from Fibre to Everything Else
a week ago
a week ago
I just viewed it.
a week ago
@Ucatchmydrift wrote:
Moved to a location where no one will view it, just like safeguard itself I see.
It was moved to a better location, as the issue isn’t to do with your connection.
The board is still part of the help area monitored by PN staff
a week ago
- Everything else
