Safeguard not blocking on one device only
- Everything else
- Safeguard not blocking on one device only
02-04-2020 2:32 PM
Hello, title basically explains it!
Safeguard's set to block themes and also specific websites and works across all devices connected to the wifi apart from my laptop, it's not a massive issue but i'd rather it work properly and work across everything.
I've turned the themes off & on again and restarted the router but still won't block it.
Any ideas?
Message 1 of 2
(347 Views)
1 REPLY 1
Re: Safeguard not blocking on one device only
02-04-2020 2:44 PM
it could be that your laptop has specific DNS configured rather than using the router ones, that'd prevent it working.
Also if you use a VPN or the like it won't work.
Message 2 of 2
(336 Views)
- Everything else
