Safeguard not blocking on one device only
ratqween
Hello, title basically explains it!
Safeguard's set to block themes and also specific websites and works across all devices connected to the wifi apart from my laptop, it's not a massive issue but i'd rather it work properly and work across everything.
I've turned the themes off & on again and restarted the router but still won't block it.
Any ideas?
Tags (1)
1 REPLY 1
Fixes: 1,485
Re: Safeguard not blocking on one device only
it could be that your laptop has specific DNS configured rather than using the router ones, that'd prevent it working.
Also if you use a VPN or the like it won't work.
