Safeguard not blocking a site
- Everything else
- Safeguard not blocking a site
- « Previous
- 1
- 2
- Next »
Re: Safeguard not blocking a site
07-09-2023 4:53 PM
As we are unaware of any issues with the safeguard side of things I have raised it to the network team to find out more info for you.
I should have an update by Monday.
I am in next week Mon-Thurs 9:30-6 so I will keep an eye on it for you.
Do you need anything else at the minute?
22-11-2023 6:44 PM
23-11-2023 9:41 AM
@Richyroo - Would you be able to turn the router off and on again and also the devices? Also, unplug any powerline adapters/boosters/meshes. Safeguard uses the DNS address to work so if a mesh/booster has gone rogue and sends out Google's DNS address for example, that will stop it from working.
23-11-2023 12:56 PM
23-11-2023 1:21 PM
The idea is to get you on a new IP address as you have been connected with the same one for at least 2 months, a few reboots should do the trick, can you reboot again and let me know so I can see if you have been allocated a different IP or you can check using https://whatismyipaddress.com . I don't think the IP address itself is the issue more the servers and access racks behind that will change as part of being allocated a new IP.
23-11-2023 10:21 PM
Thank you for explaining, that makes more sense, and less like I am just being asked to waste a bit of time ![]()
Although, given the number of times I've restarted I don't think it's going to get a new IP, is there any way I can free the lease from my end?
26-11-2023 8:33 AM
24-12-2023 11:27 AM
29-12-2023 9:18 PM
There are other articles on this forum where kids use VPNs to circumvent safeguard
- « Previous
- 1
- 2
- Next »
- Everything else
