Safeguard - blocking a site
Nottodaythanks
Re: Safeguard - blocking a site
Yours
Fixes: 1,662
@adam945's added the website to his Safeguard and he's going to check it when he's home tonight as he's in the office.
I'm working from home and I'd try but I'm using a Linksys router and playing around with the DNS servers to change it to the ones which Safeguard uses will interrupt the internet I'm currently working from.
Nottodaythanks
I do not understand this.
If there is any way to block this website with the Plusnet router, please let me know.
bobpullen
Fixes: 330
@Nottodaythanks wrote:
I tried
https://duckduckgo.com/
and
www.duckduckgo.com
You do not need to enter the http(s):// prefix.
Given DuckDuckGo favour their domain without the www prefix, then I would recommend you try blocking the site by simply entering duckduckgo.com if you haven't attempted that already. If Safeguard is already enabled then a reboot of the router is not necessary.
Nottodaythanks
That worked
Thank you!
Fixes: 1,662
Excellent! Thanks @bobpullen, I'll remember that
