SafeNet causes Chrome to stop working
Tim_c
So I've recently switched from Open DNS which was flawless to 'SafeGuard' which is...not as good. I have a strange and particular issue. Whenever SafeGaurd is on, it prevents Chrome on my work desktop connecting to any sites at all, displaying the message 'This site can't be reached.' If I use Edge or anything else, everything works fine. It is only the Chrome browser which is affected. I have 'reset' Chrome but this does not help. Plusnet phone support could only advise me to turn it of and on again.
1 REPLY 1
Fixes: 1,662
Re: SafeNet causes Chrome to stop working
Thanks for the post back @Tim_c
Ah this is really odd. When you have Safeguard on, have you tried turning off all categories and see if Chrome works then?
Also are you able to try a different device other than your work desktop?
