SafeGuard not Working
- Everything else
- SafeGuard not Working
23-07-2017 12:06 PM
Dispite following all the guidance online, including restarting my router, Safeguard is not working.
I have blocked several categories and particualr sites and whitelisted one site to test fucntionality on Friday and still it is not active.
I get E-mail confirmations that changes have been applied to my Safeguard settings via e-mail but ther is no change history being recorded within the control centre.
Anyone able to advise on what I may be doing wrong?
Browsing the forums shows sevaral others have had issues in the past.
Re: SafeGuard not Working
24-07-2017 9:45 AM
Sorry to hear Safeguard isn't working for you.
We're aware of a known issue where the correct DNS isn't being assigned and I don't believe you can change it in the router we've supplied you. To double check this is the case for you, can you go to http://192.168.1.254
Once you're there, navigate to advanced settings then go to broadband.
Primary DNS should read 213.120.234.42 and Secondary DNS should be 213.120.234.38
Let us know if that is/isn't the case?
Cheers
24-07-2017 4:47 PM
Hi Gandalf - My DNS settings do not match those you posted
Find details from Settings -
Primary DNS: | 212.159.6.10 | |
Secondary DNS: | 212.159.6.9 |
Regards
24-07-2017 4:50 PM
It's as I suspected. I've added your account to the problem we have raised [98595].
Unfortunately, I don't think it's going to be a quick fix, apologies for any inconvenience caused.
25-02-2018 3:27 PM
Superuser citation
This topic has been cited by one of the Superusers; the purpose of which is to provide a note for information which might help to focus continued discussion (but might not result in a staff response).
If this post helped, please click the Thumbs Up and if it fixed your issue, please click This fixed my problem
