Safe Surf Option
- Everything else
- Safe Surf Option
Safe Surf Option
22-11-2017 4:04 PM
Just tried to test this by setting it on in the member centre & bouncing my Plusnet connection but it seems to have no effect on BitTorrent traffic on the ports it says it blocks. Does the setting not work anymore?
Message 1 of 2
(499 Views)
1 REPLY 1
Re: Safe Surf Option
22-11-2017 6:22 PM
All the old stuff no longer has any effect, apart from the firewall. It's all PlusNet safeguard orientated these days.
That's RPM to you!!
Message 2 of 2
(482 Views)
