SQL Trigger
- Everything else
- SQL Trigger
SQL Trigger
12-08-2007 7:55 PM
Hello,
I'm having trouble creating an SQL Trigger statement. Does Plus net support Triggers?
The code I am attempting to use is:
CREATE TRIGGER first-trigger AFTER INSERT
and it always results with the following error:
ERROR 1064: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TRIGGER first_trigger AFTER INSERT' at
Has anyone else experienced, or know the solution, to such a problem?
Any help would be most appreciated.
Thanks in advance,
Logical
Thanks in advance,
Logical
Message 1 of 5
(2,510 Views)
4 REPLIES 4
Re: SQL Trigger
12-08-2007 8:02 PM
Triggers are only available in MySQL 5+
Humbug and Rumpus both have 4.1 (I believe!)
Barry
Barry
Message 2 of 5
(585 Views)
Re: SQL Trigger
13-08-2007 12:02 AM
Yep, that is correct.
PN are planning to upgrade the MySQL servers in the not to distant future to the latest MySQL 5 version.
Message 3 of 5
(585 Views)
Re: SQL Trigger
16-08-2007 9:07 PM
Quote from: Peter Yep, that is correct.
That's disapointing. When is this expected to be implemented by?
Message 4 of 5
(585 Views)
Re: SQL Trigger
17-08-2007 9:07 AM
Unfortunately we don't have a set time for this yet, the project hasn't kicked off. We should have more information in the coming weeks.
Message 5 of 5
(585 Views)
