SQL Admin username
- Everything else
- Re: SQL Admin username
SQL Admin username
30-10-2007 1:07 PM
Hey folks
i'm trying to remember what form my username takes for the sql admin access
i cant remember if its username.plus.net or username.plus.com?
Message 1 of 9
(2,921 Views)
8 REPLIES 8
30-10-2007 1:15 PM
Your username for MySQL is simply your basic account name. You don't need the domain in the login. You will have been sent an email when the account was setup, so search for that or use the help and assistance to find "Reset/Send My MySQL Database Password and Name" option and ask for a reminder from the admin team. If your already using a database on your site then you must have written the userid and password into a database connection file so look for that so your site will keep working rather than getting it changed.
Message 2 of 9
(909 Views)
30-10-2007 1:26 PM
Dodgy spam filters throwing the message away no doubt as it comes from a machine and not a person. So if you don't get the email in the expected time then ask for it again. Or just check your junk mail box.
Message 3 of 9
(909 Views)
30-10-2007 1:59 PM
yeah i cant find the email with the password anywhere.
your saying the password should be listed in a file somewhere in my ccgi webspace? i run a php forum.
Message 4 of 9
(909 Views)
30-10-2007 2:38 PM
Quote from: James_H your username and password are the same as the ones you use to log into the portal ( http://portal.plus.com )
yeah, was affriad you where going to say that, it dont work
Message 5 of 9
(909 Views)
30-10-2007 2:59 PM
yeah i'll raise a ticket, never changed it.
Message 6 of 9
(909 Views)
30-10-2007 6:18 PM
Quote from: Merrick yeah i cant find the email with the password anywhere.
if the php forum files are still on your ccgi space have a look in config.php your password will be in there
Message 7 of 9
(909 Views)
31-10-2007 12:44 PM
The userid is the same as used for the portal. But the password is different. As stated previously if your actually using your mySQL database on your website then in your code you will find a mysql_connect statement which has the userid and password in it. Or at least reference to some variables which contact this information. Typically you'd put that in some sort of config, or dbconnect file so that it's shared by all your routines rather than repeating the password in every file. If you have your password reset your site will stop working until you change the password in your code to match.
Message 8 of 9
(909 Views)
01-11-2007 9:47 PM
euh ..
$> cat < config.php | grep dbpass
(or what ever the database password variable name is)
the power of Command Line and SSH ... xD
Hopefully one of the many ways of righting this fault has worked
Jim,
Jim,
Message 9 of 9
(909 Views)
- Everything else
