SMF
SMF
05-04-2007 9:42 PM
Re: SMF
05-04-2007 10:09 PM
you can get it from http://www.simplemachines.org/ if you want to have a looky
Re: SMF
05-04-2007 10:19 PM
Re: SMF
06-04-2007 8:31 AM
Re: SMF
06-04-2007 9:12 AM
Although it doesnt take much, I found this usefull from a time aspect.
Re: SMF
07-04-2007 12:13 PM
Quote from: HSNetwork Best bit about it is that unlike most others SMF can (if you want it to) set all the perms for the files and folders for you during installation.
I got to add that this is the bane of my (on line) life ... I have lost track of the number of people who have come to me with problems with the boards their setting up and its been down to permissions
Starlord
Re: SMF
10-04-2007 11:05 AM
Quote from: Liam Yep. I got it up and running without any problems using our CCGI / MySQL servers.
Any chance of giving a quick guide or is it really that simple?
Re: SMF
11-04-2007 8:16 AM
Quote from: Chris
Its as simple as upload the files to CGI, and run the install.php file!
It asks for all the details (SQL etc) during the 'install'
Re: SMF
11-04-2007 11:42 AM
Re: SMF
13-04-2007 2:42 PM
Re: SMF
25-04-2007 5:04 PM
The good thing with that is it asks for al the details and does it all itself. So really there is nothing more to do other than run the install.php script.
Re: SMF
06-08-2007 7:04 PM
Quote from: Teatime I'm quite liking what SMF offers... And it's free? Is it possible/feasible to install it in our own CGI space?
If you're using Joomla at the moment, insted of using SMF & then having to use a bridge to joomla, have a peep at Fireboard, it may only be at beta 1.02 RC2 but it is (in my humble opinion) far better than any other Forums out there currently
