SMF forum won't work on CCGI
- Everything else
- SMF forum won't work on CCGI
08-03-2008 8:16 AM
08-03-2008 11:56 AM
I have SMF forums running on ccgi.
08-03-2008 8:31 PM
The CGI platform is not working properly, why do I say this because Scott has had more trouble van it is werth.
[Edit]
Link Removed, the Forum is up and working.
08-03-2008 8:59 PM
Quote from: Midnight Hi jelv see this that mcgurka aka Scott done for me.
The CGI platform is not working properly, why do I say this because Scott has had more trouble van it is werth.![]()
That looks like it either can't find the stylesheet or the stylesheet isn't formatted properly. Are you sure it has been uploaded to the path http://ccgi.dyslexia.force9.co.uk/cgi-bin/forum/Themes/classic/style.css and/or has suitable permissions applied? Just a thought.
08-03-2008 9:30 PM
Moderators can you split the last few posts out to a separate topic please as this is nothing to do with php5 as SMF 1.1.4 runs perfectly well under php4 on ccgi.
08-03-2008 10:11 PM
Re: SMF forum won't work on CCGI
09-03-2008 9:13 PM
13-03-2008 9:55 PM
Now I have a different problem. After having trouble clearing the cgi-bin folder I had the webspace cleared and reset by Plusnet and ftp'd the website and forum folder back on but in the root directory. Now the webpages are accessible but I can't navigate to the forum folder to run the php install script.
All permissions set via chmod 755
Anybody any ideas?
Website at :- http://ccgi.widlof.force9.co.uk
FTP screen shots:- http://ccgi.widlof.force9.co.uk/images/ftpscreenshot.jpg
& http://ccgi.widlof.force9.co.uk/images/forumscreenshot.jpg
13-03-2008 10:19 PM
Note: you have used a capital F in forum which is not something I would recommend. The CCGI server uses *nix (Apache) and all filenames are case sensitive, unlike WIndows where Forum and forum are the same..
You need to login to the ccgi shell and run fixphpperms.sh -r to correctly set the file permissions on all php files. Then you can run the setup.
13-03-2008 11:04 PM
Changing the F to f has sorted the access problem but excuse my ignorance how do I login to the ccgi shell? Sorry!
Mike
13-03-2008 11:25 PM
14-03-2008 12:03 AM
- Everything else
