SMF forum won't work on CCGI
- Everything else
- Re: SMF forum won't work on CCGI
08-03-2008 8:16 AM
08-03-2008 11:56 AM
I have SMF forums running on ccgi.
08-03-2008 8:31 PM
The CGI platform is not working properly, why do I say this because Scott has had more trouble van it is werth.
[Edit]
Link Removed, the Forum is up and working.
08-03-2008 8:59 PM
Quote from: Midnight Hi jelv see this that mcgurka aka Scott done for me.
That looks like it either can't find the stylesheet or the stylesheet isn't formatted properly. Are you sure it has been uploaded to the path http://ccgi.dyslexia.force9.co.uk/cgi-bin/forum/Themes/classic/style.css and/or has suitable permissions applied? Just a thought.
08-03-2008 9:30 PM
Moderators can you split the last few posts out to a separate topic please as this is nothing to do with php5 as SMF 1.1.4 runs perfectly well under php4 on ccgi.
08-03-2008 10:11 PM
09-03-2008 9:13 PM
13-03-2008 9:55 PM
Now I have a different problem. After having trouble clearing the cgi-bin folder I had the webspace cleared and reset by Plusnet and ftp'd the website and forum folder back on but in the root directory. Now the webpages are accessible but I can't navigate to the forum folder to run the php install script.
All permissions set via chmod 755
Anybody any ideas?
Website at :- http://ccgi.widlof.force9.co.uk
FTP screen shots:- http://ccgi.widlof.force9.co.uk/images/ftpscreenshot.jpg
& http://ccgi.widlof.force9.co.uk/images/forumscreenshot.jpg
13-03-2008 10:19 PM
Note: you have used a capital F in forum which is not something I would recommend. The CCGI server uses *nix (Apache) and all filenames are case sensitive, unlike WIndows where Forum and forum are the same..
You need to login to the ccgi shell and run fixphpperms.sh -r to correctly set the file permissions on all php files. Then you can run the setup.
13-03-2008 11:04 PM
Changing the F to f has sorted the access problem but excuse my ignorance how do I login to the ccgi shell? Sorry!
Mike
13-03-2008 11:25 PM
14-03-2008 12:03 AM
- Everything else
