$_SERVER['PHP_AUTH_USER'] not working
- Everything else
- $_SERVER['PHP_AUTH_USER'] not working
20-01-2008 12:05 PM
Hi
Trying to use
to get username from htaccess login but it returns nothing. Same with $_SERVER['REMOTE_USER'] not working.
Any ideas
Trying to use
<?php echo $_SERVER['PHP_AUTH_USER'] ?>
Any ideas
Message 1 of 2
(6,883 Views)
1 REPLY 1
Re: $_SERVER['PHP_AUTH_USER'] not working
20-01-2008 1:45 PM
Our CCGi service uses PHP as a CGI wrapper and is not installed as a module.
As per the PHP documentation, this specific feature is not available in this configuration.
http://uk.php.net/manual/en/features.http-auth.php
There are some minor workarounds which are available in the above link for CGI mode, however these are not available on CGI either, unless you do some other mod_rewrite work to make your site work.
Message 2 of 2
(813 Views)
- Everything else
