Ring Door Bell interfere with Other wifi connected devices
KSW
Hi
my ring door bell interferes with other connected devices. If you are on a PC or wifi phone call and someone rings the doorbell the other connected device cuts off. Any ideas?
12 REPLIES 12
Fixes: 459
Re: Ring Door Bell interfere with Other wifi connected devices
What is the upload speed on your internet connection ?
The ring doorbell will upload an HD video when someone presses the doorbell. Dpending on how good your upload speed is, it may 'swamp' the connection.
SammyM
Fixes: 101
Hiya @KSW,
I have checked the estimates for your line and it is showing your upload speed of 1.2Mbps, it could be as MisterW says causing the issue.
Do you experience drops out when using other devices or streaming at all? or is it solely the bell?
 Sammy M - Sheffield Team
Fixes: 459
@SammyM  is that ADSL or FTTC ?
Fixes: 1,612
@MisterW, it's FTTC, I've attached a screenshot of the estimates below:
I've also tested their line and the speeds are within the estimates, due to how long the line is back to the cabinet.
Here's the full test I've ran:
GEA Test Detail
Circuit ID NA Service ID [redacted]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 19.1 Mbps
Upstream Speed 1.2 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 1671.4
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From15:15to10:45
Interference Location Customer Premise
Interference Observed In Days 14
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-20M Downstream, Retransmission High - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2022-02-02T10:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Stream Line Rate 1.2 Mbps 1.2 Mbps 1.2 Mbps
Up Time 788.0 Sec 900.0 Sec 899.8 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2022-02-15T10:06:00Z 2022-02-15T10:21:00Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Fixes: 459
Yikes, that's one lo...ng line!. As you, say its well withing estimates.
Problem is, with only 1.2Mb upload , I dont see how its going to support a doorbell trying to upload HD video. I'm not surprised that any other devices lose internet access, the doorbell is going to be saturating the upload bandwidth.
KSW
Thanks it sound about right we are still waiting for fibre☹️
KSW
Just the bell
Legend
Fixes: 293
@KSW You are already on Fibre To The Cabinet - do you mean Fibre To The Premises?
Fixes: 1,612
@MisterW aye, not as long as this line though.
@KSW, fingers crossed FTTP comes soon for you! You can check if there are any plans at https://www.openreach.com/
198kHz
Fixes: 41
Just a thought - re-reading the OP
Has it been established whether the 'other device' just struggles to maintain any upstream data, are does it actually drop its WiFi connection to the router?
BT technician (Retired)
Fixes: 179
Or can the settings on the bell be changed to send lower resolution images?
Fixes: 1,486
Not on the ring doorbell I have.
My neighbour had the same issue with a 1Mbit ADSL upload, saturated everything.
