Ring Door Bell interfere with Other wifi connected devices
- Everything else
- Ring Door Bell interfere with Other wifi connected...
14-02-2022 1:35 PM
Hi
my ring door bell interferes with other connected devices. If you are on a PC or wifi phone call and someone rings the doorbell the other connected device cuts off. Any ideas?
Re: Ring Door Bell interfere with Other wifi connected devices
14-02-2022 2:51 PM - edited 14-02-2022 2:51 PM
What is the upload speed on your internet connection ?
The ring doorbell will upload an HD video when someone presses the doorbell. Dpending on how good your upload speed is, it may 'swamp' the connection.
14-02-2022 6:25 PM
Hiya @KSW,
I have checked the estimates for your line and it is showing your upload speed of 1.2Mbps, it could be as MisterW says causing the issue.
Do you experience drops out when using other devices or streaming at all? or is it solely the bell?
14-02-2022 6:30 PM
@SammyM is that ADSL or FTTC ?
15-02-2022 10:29 AM - edited 15-02-2022 10:29 AM
@MisterW, it's FTTC, I've attached a screenshot of the estimates below:
I've also tested their line and the speeds are within the estimates, due to how long the line is back to the cabinet.
Here's the full test I've ran:
GEA Test Detail | |||
Circuit ID | NA | Service ID | [redacted] |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 19.1 Mbps | ||||
Upstream Speed | 1.2 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 1671.4 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From15:15to10:45 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 14 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream traffic detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
DP Type | External | ||||
Profile Name | 0.128M-20M Downstream, Retransmission High - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2022-02-02T10:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Stream Line Rate | 1.2 Mbps | 1.2 Mbps | 1.2 Mbps |
Up Time | 788.0 Sec | 900.0 Sec | 899.8 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2022-02-15T10:06:00Z | 2022-02-15T10:21:00Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
15-02-2022 10:41 AM - edited 15-02-2022 10:42 AM
Yikes, that's one lo...ng line!. As you, say its well withing estimates.
Problem is, with only 1.2Mb upload , I dont see how its going to support a doorbell trying to upload HD video. I'm not surprised that any other devices lose internet access, the doorbell is going to be saturating the upload bandwidth.
15-02-2022 12:23 PM
Thanks it sound about right we are still waiting for fibre☹️
15-02-2022 12:23 PM
Just the bell
15-02-2022 12:36 PM
15-02-2022 3:17 PM
@MisterW aye, not as long as this line though.
@KSW, fingers crossed FTTP comes soon for you! You can check if there are any plans at https://www.openreach.com/
15-02-2022 4:31 PM
Just a thought - re-reading the OP
Has it been established whether the 'other device' just struggles to maintain any upstream data, are does it actually drop its WiFi connection to the router?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
19-03-2022 4:27 PM
19-03-2022 8:17 PM
My neighbour had the same issue with a 1Mbit ADSL upload, saturated everything.
- Everything else
