Reward Card lower than expected
jfitzw7
Received my reward card a few weeks ago, with half the amount I was promised. £50 allocated instead of £100.
I contacted Purecard support, and they responded "As we are a third party company, we are provided the information directly from Plusnet. If the amount is incorrect you will need to contact Plusnet directly"
I contacted Plusnet via the usual support number, provided my details, and got told the exact same: Contact Purecard/Blackhawk directly "As they are a third party".
My assumption: I commenced the sign up process via BroadbandChoices, listing a £100 reward card for joining. The site failed to return a result on whether I could purchase the FTTP package for my property, so I rang support directly to get a proper confirmation. The customer support rep then led me through the rest of the purchase, and completed it over the phone. Which I expect, led me to recieve the main site's advertised £50 instead.
I hardly would have found it logical to hang up while the opportunity was presented to me there, but I was never informed I would be receiving a lower reward amount for doing such, in which case I would have immediately. Is there any way I can recieve the amount I was informed about in the first place?
1 REPLY 1
Lesley_W
Re: Reward Card lower than expected
Hi @jfitzw7
Welcome to our community.
I understand your disappointment, offers can differ between our website and that of third parties.
If you feel that based on the conversation you had when taking the contact, you were not advised of the correct amount, you can contact our team to discuss this further.
Lesley
