Reverse DNS update
FIXED- Subscribe to RSS Feed
- Everything else
- Re: Reverse DNS update
20-07-2021 11:12 PM
Hello, it seems from a search that this is the place to ask since the Help Assistant signposted is no longer working.
Could I please have a reverse DNS update? I'm already using a custom hostname but wanted to update it as it's conflicting with a name I now use for something else, and I want RDNS to continue matching for SMTP. Thank you.
Fixed! Go to the fix.
21-07-2021 10:37 AM
Hi @Veri,
Just to clarify, what did you want the rDNS to be updated to? If this contains confidential information, please send it over on a Private Message.
22-07-2021 9:25 AM
Looks done. Thanks for sorting this so efficiently :).
- Everything else
