Reverse DNS (rDNS) Request
- Everything else
- Reverse DNS (rDNS) Request
17-06-2024 11:44 AM
Hello,
Could I get the reverse DNS (PTR) for my static IP changed from username.plus.com to staticip.plus.com?
Could you confirm that this change would also remove the username.plus.com A record?
Please send PM for username/IP.
Thanks!
Re: Reverse DNS (rDNS) Request
17-06-2024 11:51 AM
@Lumen it would remove it for you. I am going to pm you to get your username ![]()
17-06-2024 11:53 AM - edited 17-06-2024 11:56 AM
@willcutforth are you sure about that Will ? I don't think it will. The forward pointing <accountname>.plus.com A record won't be affected by a change in the rDNS
- Everything else
