Reverse DNS on my Dynamic IP shows my Plusnet username
All Star
Fixes: 30
Hi, I noticed recently when I perform a reverse DNS lookup of my Dynamic IP address, it returns my plusnet username which I understand should not normally be possible with a Dynamic IP from Plusnet.
ie..  username.plus.com
I recall many many years ago, there was a Plusnet network wide problem (I think it had something to do with packet loss through certain plusnet gateways affecting multiple customers).   I vaguely recall I may have been assigned a temporary static IP address to help Plusnet fault find.   I believe the static IP was later removed and I reverted to normal Dynamic IP assignment.
Yesterday, I opened a ticket via Plusnet website, to request my username is removed from rDNS lookups because I have a Dynamic IP.  Ticket no. 209418574
Unfortunately, I think the agent who has responded to the ticket this afternoon, may not have understood my request, or I didn't explain it very well.
Please could another agent look at the ticket?
5 REPLIES 5
Fixes: 963
Re: Reverse DNS on my Dynamic IP shows my Plusnet username
Thanks for your post @bill888
I'm sorry for the confusion. From what I can see you have a static IP we've added free of charge. We've started doing this as of the last year or so due to some changes we've made internally. We'd add a static IP if you go into failed payment, or have the Pro-Addon, or Broadband Firewall enabled on your account.
As it's not possible for us to remove the static IP unless the above criteria's not met, I've raised a task with our NetOps team to change the rDNS records. I've added more specific information onto your ticket 209418574.
I hope this helps. Smiley
All Star
Fixes: 30
oh, I didn't realise I now had a static IP.
If I was to turn off the Firewall, will my account automatically revert to 'Dynamic IP' and remove the rDNS entry that displays my Plusnet username?    (I suspect 'No' ?)
Fixes: 963
Thanks for getting back to me @bill888
Yes it should do although it may take 24-48 hours to automatically remove the forced static IP.
We can manually remove this but the system will automatically add it back on if one of the 3 criteria's met.
Having said that, I've had confirmation just now that your reverse DNS has now been updated and the changes should take effect within 24 hours. Smiley
All Star
Fixes: 30
Thank you for your help.  The rDNS change was completed this morning.
I'll consider turning off the firewall (I think it was set to 'Low' setting from when I joined Plusent over a decade ago) to revert back to a Dynamic IP later.
Fixes: 963
Awesome, no problem at all.
Let me know if there's anything else you'd need help with
