Reverse DNS change request
BaxMaxTuck
My Reverse DNS is currently in the format <username>.plus.com, could I please have it changed so that my static-IP replaces my <username>.
Hopefully I've posted this in the right place.
Kind Regards, Chris
2 REPLIES 2
RealAleMadrid
Seasoned Champion
Fixes: 43
Re: Reverse DNS change request
@BaxMaxTuck  You may get a quicker response if you raise a question/ticket in your member centre account. See message #5 in the thread linked below. This seems to be one of the few things for which you can raise a ticket.😊
https://community.plus.net/t5/Everything-else/reverse-dns-for-static-ip-no-longer-possible/m-p/17003...
BaxMaxTuck
Thanks for the advice @RealAleMadrid. I've raised a question 👍
