Remove username from rDNS on static IP
adam24
Hi, there seems to be a privacy leak through rDNS on my static IP where my username is revealed in the hostname. Like many resolved threads before, this seems to be the way to request the removal of my username from the hostname. Please can this be cleared for me? I hear it can be set to {ip address}.plus.com or similar, which would be fine.
Many thanks
2 REPLIES 2
Fixes: 479
Re: Remove username from rDNS on static IP
Moderator's note:
Thread moved from Broadband to Everything Else
James30
Fixes: 32
@adam24  Hi, please reply to this ticket @ https://www.plus.net/wizard/?p=view_question&id=242797052 and we'll send a request off to change that for you.
James - Plusnet Sheffield
