Remove Plusnet username from Reverse DNS lookup
- Everything else
- Remove Plusnet username from Reverse DNS lookup
20-04-2023 10:23 PM
Hi all.
Would it be possible to amend the reverse DNS entry on my static IP address so that it doesn't display my Plusnet username?
(from looking at previous posts on this subject I can see it can be changed to something generic like username.plus.com - if this can still be done that'd be great)
Thanks in advance!
Nathan.
Re: Remove Plusnet username from Reverse DNS lookup
21-04-2023 11:47 AM
Hey @snathe1978 I can get this actioned it can be:
- Your username.plus.com like yours is
- Static IP
- Your domain, so long as it is pointing to your static
Which one would you like?
21-04-2023 11:58 AM - edited 21-04-2023 11:59 AM
Hi @willcutforth
Happy to go with the second option you mentioned, just want to get my actual user name removed!
(Just to check - will this be the string "staticip.plus.com" or "[my actual static ip address].plus.com"?)
Nathan.
21-04-2023 12:05 PM
21-04-2023 12:09 PM
This is the ticket https://www.plus.net/wizard/?p=view_question&id=233255030
25-04-2023 2:42 PM
Just to confirm this has now been done - thank you for resolving it!
- Everything else
