Remove PC from McAfee
meatloaf01
I have Plusnet McAfee associated with two PCs which are now redundant.
How do I remove them from McAfee on my Plusnet account?
Many thanks
5 REPLIES 5
Fixes: 1,577
Re: Remove PC from McAfee
Hi there.
As far as I'm aware I believe there should be a way if you go into the settings of the McAfee software.
Failing that as an alternative we'll be happy to arrange for McAfee to call you back to arrange this.
Feel free to PM me the best contact number and a rough timeframe for a call if you'd like to go ahead.
meatloaf01
Thanks for your reply. The PCs in question don’t exist anymore - they’ve been dismantled. But they are still listed in the McAfee ‘dashboard’ on my Plusnet account. Contact with McAfee appreciated. I should be free most of tomorrow but after 4pm would be best on  [Removed]
I’m just about to install McAfee on my new PC. That will be my third listing.
Moderators Note: Personal info removed
@meatloaf01 - You need to remove your private number, this is a public forum.
meatloaf01
Thanks - done by moderator.
Fixes: 1,577
Thanks for getting back to us.
I've arranged for McAfee to call you back tomorrow after 4pm.
Let us know how the call goes.
