Regard mcafee
Robertshaw15
Regard mcafee
We're do I find the code for the mcafee so I can put it on my computer please thank u
7 REPLIES 7
alanf
Re: Regard mcafee
If you are referring to Plusnet Protect Powered By McAfee then "You can add Plusnet Protect in the Member Centre on our Add-Ons page."
https://www.plus.net/home-broadband/protect/
decomplexity
Re: Regard mcafee
It is not a good idea to put all your trust in McAfee Internet Security or the other McAfee  anti-malware products. Compared with Kaspersky Internet Security or even the venerable Norton/Symantec equivalents, its ability to identify malware is poor.
Zen from May 17. PN Business account from 2004 - 2017
Fixes: 156
Re: Regard mcafee
Few would agree with that assessment....
https://www.toptenantivirus.co.uk/?gclid=EAIaIQobChMIoYXghpeW1QIVmqntCh1IQAP2EAAYASAAEgIfQvD_BwE
http://uk.pcmag.com/antivirus-reviews/8141/guide/the-best-antivirus-protection-of-2017
https://www.av-test.org/en/antivirus/home-windows/
Mcafee has a long history of being a sound product. In my experience Norton creates as many problems as it claims to fix.
Oldjim
Resting Legend
Fixes: 63
Re: Regard mcafee
Well I would
Take your link to Avtest - Mcafee comes third from last for protection
and this one third from last again http://chart.av-comparatives.org/chart1.php?chart=chart2&year=2017&month=Feb_Jun&sort=1&zoom=4
Fixes: 156
Re: Regard mcafee
Jim,
I speak from the experience of working for a major international IT firm. We used McAfee for years with no real issues. Then some accountant bod secured a cheaper deal with Norton ... and all hell broke out.
Oldjim
Resting Legend
Fixes: 63
Re: Regard mcafee
So you are comparing the Business Version and the Consumer version is rather different
I suggest you look at the independent tests - the link you showed and mine - and McAfee has been going downhill for many years
Symantec used to be a resource hog but they sorted that out a few years ago
decomplexity
Re: Regard mcafee
"I speak from the experience of working for a major international IT firm. "
Then you will also be aware that, in addition to PC-based anti-malware programs, businesses run hardened security appliances on the periphery of their network. If they run a DMZ that contains public-facing web servers and email servers, they may run two appliances (or two farms of appliances) - one to protect their public-facing services and one on the inward side of the DMZ to protect their internal users.
They usually run a hardened version of a UNIX variant or a special purpose operating system
McAfee sell security appliances, and one hopes that they are more secure than their PC-based brethren.
