Recessing BT wall sockets.
- Everything else
- Recessing BT wall sockets.
11-11-2016 12:08 PM
I’ve put this message in this forum as I thought it was the best place as it is applicable to ADSL as well as VDSL but if it needs relocating then please do so.
I have on my hall wall two Mk3 BT ADSL sockets, is there anyway I can have these recessed into the wall. I know it will only save about a 1cm of space, but all the same it’s something I would like done.
Re: Recessing BT wall sockets.
11-11-2016 12:16 PM - edited 11-11-2016 12:18 PM
It's pretty standard type of back box, so why not?
The trick will be deciding who does it and how.... (Can't imagine BT would be interested and in theory no-one else should)
Mine is semi-recessed, in that it half-overlaps the skirting board which goes around it. So someone at some time must have moved it.......
11-11-2016 12:54 PM
Yes, in theory a couple of plaster wall socket recess boxes could do it and I could do it myself, but it is allowed?
I agree with you regarding BTs interest, so maybe I'm on a hiding to nothing as I don't want to do it when it could have repercussions.
11-11-2016 12:59 PM
Mmm, I've just taken a closer look at these sockets and from what I see they may not even be capable of being recessed!
11-11-2016 3:45 PM
There is a danger of course that you could disrupt the cable (easily done) and finish up having to pay any call out fee. Having said that I recessed mine and it does look a lot neater.
Don't limit the friends you haven't met with arguments you'll never have.
11-11-2016 3:48 PM
@Minivanman - Any chance you could provide of picture of that please, I'd be interested to see what you did.
11-11-2016 4:30 PM - edited 11-11-2016 4:38 PM
Here you go Mook.
The original socket was flush with the wall until BT changed it for a double Mk 3 facia which which brought it out by about half an inch. It's on a plasterboard wall with plenty of depth, but not enough to make it worth changing for such a small amount. The previous one stuck out about an inch and a half!
Hope this helps.
- Everything else
