Wi-Fi Adaptor query
Fixes: 88
Re: Wi-Fi Adaptor query
@pvmb
How far from the external wall to the duct? It would appear digging is required which would delay installion as ground works is the responsibility of a different team from house installs. The latter can't be done until the former is completed.
The good news is that this may require a survey first and if you catch the surveyor on the day then you can speak about the location of the ONT.
pvmb
Fixes: 7
I tried removing USB wireless adaptor from rear of PC and plugging in to USB port on front.
Result? Exactly the same as before: PC still reporting adaptor speeds of 867 Mbps on 5GHz (maximum quoted spec.), but only 173.5 Mbps on 2.5 GHz (quoted maximum spec. 400 Mbps)
Strange...
Anyone have any knowledge of maximum 2.5GHz Wi-Fi link speed with Hub 2 router?
Fixes: 527
@pvmb this https://superuser.com/questions/1226681/why-is-my-wi-fi-router-showing-link-speed-of-72-mbps is worth a read
pvmb
Fixes: 7
Thanks MisterW, lots of linked to reading there. I also learned a new word: 'cromulent' (might come in useful at Scrabble).
Reading about Wi-Fi speeds rather brought to mind DAB radio. Super! Oh no it isn't... 😞
https://www.xda-developers.com/how-to-double-the-wifi-speed-on-your-oneplus-3-3t/
https://arstechnica.com/information-technology/2017/03/802-eleventy-what-a-deep-dive-into-why-wi-fi-...
paul_blitz
Fixes: 4
CAT 5, 6 and 7 all provide 4 pairs (= 8 wires), whether 2 or 4 pairs are actually USED depends on the connection: 10 meg and 100 meg (aka Fast Ethernet) ethernet just need 2 pairs (can be CAT 5, 6 or 7!), but Gigabit ethernet needs 4 pairs.
Yes, old CAT5 will work for gigabit, but might have issues on longer runs. CAT5e is higher performance, so WILL work ok on longer runs. CAT6 supports up to10 gigabit speeds.
(CAT7 also supports 10 gigabits, but is a very high performance cable, aimed at noisy electrical environments, like data centres, so is overkill for home / office use...and costs a lot more!)
Telephone wiring is CAT3, typically has 4 wires, and will work with ethernet at 10 meg (and maybe even 100 meg for short lengths, with a good tail wind!)
pvmb
Fixes: 7
A little more on Wi-Fi Link speeds:
What does the link speed of a WiFi connection depend upon?
https://superuser.com/questions/1222561/what-does-the-link-speed-of-a-wifi-connection-depend-upon#12...
pvmb
Fixes: 7
Re: Wi-Fi Adaptor query - An answer(?)
Better late than never! I may as well post my answer to this query I posted in September 2024
https://community.plus.net/t5/Everything-else/Wi-Fi-Adaptor-query/td-p/1985720
Briefly: Why does my TP-Link USB AC1300 Wi-Fi dongle report speeds significantly below its maximum specified "400 Mbps on 2.4 GHz" but always shows full speed on it's maximum specified "867 Mbps on 5 GHz" when checked on the PC?
The simple, but puzzling, answer (which I came to suspect) was because seemingly on 2.4 GHz the device driver reports the operational speed of the link, whereas on 5 GHz it reports the device characteristics (i.e. it is an 867 Mbps capable device)!
Now that I routinely use the AC1300 to connect to my Hub 2 router, only on 5 GHz Wi-Fi, I can see from the router logs that it actually connects at various speeds from time to time, typically around 600-700 Mbps
PhilipHeyes
For a typical 2.4Ghz Wi-Fi service operating at 20Mhz bandwidth, the Wi-Fi connection speed will max at 72Mbps,
this gives a real world throughput limit of about 50 to 55 Mbps on a speed test / file transfer.
The connect rate of 72Mbps or lower can be seen in the network info of your computer.
