Re: VPN not working
- Everything else
- Re: VPN not working
Re: VPN not working
16-11-2018 10:51 AM
Hi - need assistance on VPN / Remote desktop...
Have a plusnet hub one - delivered this week - all works behind the firewall, including Remote desktop and VPN but am unable to access home network remotely... i.e. port forwarding appears not to work..
As far as I can tell, It is set up correctly on the hub.. I have a static IP address - what might be the problem?
Any help appreciated
Chris
Re: VPN not working
16-11-2018 1:27 PM
Moderators Note
This post has been split from a different topic into a new thread for better visibility.
Re: VPN not working
16-11-2018 9:08 PM
Hi Roonie,
Is the static IP address you refer to the LAN static IP address or a Plusnet assigned WAN static IP address?
You will need both.
If the VPN works in the LAN are you using a 192.168.1.x IP address to connect to it?
I do not use a Hub One router but I *think* I have read on these forums that port forwarding can be problematic, if the routers ship server is not used to assign the LAN IP address.
To keep the same LAN IP address after a router reboot etc, address reservation can be used.
Regards
Richard
Re: VPN not working
18-11-2018 12:44 AM
Sorted.... Kaspersky firewall had blocked the ports!!!
Re: VPN not working
19-11-2018 10:50 AM
