Re: Reverse DNS Change please
peterbr
I registered a question reference 185311487 on Thursday morning last week to request for my rDNS to be changed.
After phoning back, I was told it would take 72 hours, but still nothing.
Please can you update my rDNS to the domain in the question ref. above.
9 REPLIES 9
Fixes: 1,474
Moderators Note
This topic has been split and moved from Fibre to Everything Else
MatthewWheeler
Fixes: 456
@peterbr Sorry to hear this.
We'll get this chased up for you and the account updated shortly
 Matthew Wheeler
peterbr
Hi Matthew,
Thanks for helping out.
I see your response and it definitely resolves to the correct IP. It's a subdomain though, but still resolves correctly.
Please can you check it again and check my response with the screenshot from a 3rd party.
Thanks,
Peter
JOLO
Fixes: 77
@peterbr,
When we try and add the rDNS for you it fails because, while the records are on nslookup, it doesn't look built properly. Please can you remove the A record and re-add it so we can retry.
peterbr
Hi JOLO,
I have just updated to an A name record. It was a cname.
Please can you try it again.
Thanks for helping.
peterbr
The A record is updated.
Can you try adding the rDNS again.
Thanks.
HarryB
Fixes: 256
Thanks @peterbr,
I've put that change through now and it should take effect within the next 24 hours for you.
I've also confirmed this via the ticket on your account.
I hope this helps.
 Harry Beesley
peterbr
Great - all worked well. My rDNS is correct now.
Thank you very much!
HarryB
Fixes: 256
Glad to hear that's sorted, thanks for letting us know.
 Harry Beesley
