Re: 3 days for an Irrelavant response.
- Everything else
- Re: 3 days for an Irrelavant response.
22-01-2011 6:00 PM
I asked for my webspace to be reset as it dosent seem to like running PHP scripts at all, and yes i have uploaded them to my CGI webspace, and i have activated my sql and CGI. i have updated the permissions on the scripts, as was the response from plusnet.
Message 1 of 2
(753 Views)
1 REPLY 1
22-01-2011 7:43 PM
Create a file called info.php and add:
Upload the file to your website and access it via ccgi.[username].plus.net and see if it works.
<?php phpinfo(); ?>
Message 2 of 2
(189 Views)
- Everything else
