RDNS needed
RH2
RDNS needed
Hi i have a static IP 212.159.106.161  and require it RDNS changed to reflect mx.nipperbout.com
6 REPLIES 6
Fixes: 1,483
Re: RDNS needed
Moderators Note
This topic has been moved from Fibre to Everything Else
adam945
Fixes: 113
Re: RDNS needed
Hi @RH2
Thanks a lot for reaching out.
To use this option you will need to configure the forward record on the domain. We are required to prove you own the domain before any changes can be made and this will serve as verification. The domain can be hosted on the account or externally.
 Adam
 Plusnet Help Team - Leeds
RH2
Re: RDNS needed
william@Williams-MacBook-Pro-2 ~ % dig mx.nipperbout.com +short
212.159.106.161
Forward already set up
adam945
Fixes: 113
Re: RDNS needed
Great stuff Smiley
That's all been raised for you. I'll give you a shout once I've had a response. Let me know if you need anything else in the meantime.
 Adam
adam945
Fixes: 113
Re: RDNS needed
Good morning @RH2
Just letting you know, our Team have now set your rDNS if you'd like to have a look. Let us know if you're having any issues at all. Smiley
 Adam
RH2
Re: RDNS needed
william@Williams-MacBook-Pro-2 ~ % dig -x 212.159.106.161 +short
mx.nipperbout.com.
Thank you
