Purecard Usage
Pnokio
Purecard Usage
Hi Folks, I have used all in my Purecard, will I need it in the future or just delete access to it?
Regards George
2 REPLIES 2
Christopher_G
Fixes: 5
Re: Purecard Usage
Hi @Pnokio
Welcome to the community. Smiley
If you've spent the full balance on your PureCard, I'd recommend keeping access to the account for now rather than deleting it immediately.
The PureCard account can still be useful for checking previous transactions and card details, and if there are any issues or queries about the reward card later, having access can make things easier.
Once you're sure you won't need the account or transaction history, you can decide whether to close it.
Hope that helps.
Chris
Pnokio
Re: Purecard Usage
Hi Christopher_G, I know I am not permitted to add funds to it or even change the PIN. Just in case Plusnet decide to give me anything I will leave as it is.
Regards George
