Protecting access to .php files
- Everything else
- Re: Protecting access to .php files
18-09-2007 12:34 PM
I have just read the posting at
http://community.plus.net/forum/index.php?topic=465.0
that tells me I cannot use .htaccess/.htpasswd to protect .php files.
Is there any other way of restricting access to .php files or am I stuck with them being publicly accessible?
Message 1 of 5
(2,253 Views)
4 REPLIES 4
18-09-2007 12:40 PM
There is no way to protect access to php files on the ccgi server.
The only option you have is to add some form of authentication protection at the beginning of each file so it will only be run if say the user is logged in.
Message 2 of 5
(397 Views)
18-09-2007 10:04 PM
Quote from: Peter There is no way to protect access to php files on the ccgi server.
Thanks - can you point me to a reference on how to do this? (I'm a PHP beginner.)
Message 3 of 5
(397 Views)
18-09-2007 10:10 PM
Are you writing your own code or trying to install an existing package like a forum?
If you own code, do a google search for php authentication or look at www.hotscripts.com for authentication scripts. They should then have a method to protect php files.
If you are installing someone elses code then I suspect you will not be in a position to modify it without a lot of php experience.
Message 4 of 5
(397 Views)
18-09-2007 11:39 PM
Quote from: Peter Are you writing your own code or trying to install an existing package like a forum?
Thanks for that. I am writing my own code - learning to use php as I go. That sounds like a useful site to know about. I'll take a look there and see if I can find something suitably simple.
Message 5 of 5
(397 Views)
- Everything else
