Problems with Zencart installation on Plusnet
- Everything else
- Problems with Zencart installation on Plusnet
12-10-2009 9:20 AM
I have uploaded Zencart to the plusnet CGI server OK, then I run the install interface but I dont get any graphics, it is just a plain screen with text boxes, however the installation proceeds and completes fine. When I log into the Admin interface again the screen is plain with just text down the left hand side, not the usual Zencart Interface, when I click onto any sub-category nothing happens!!!!! Does anyone have any suggestions, it an incompatability of Plusnet servers or do I need to change some setting.
Message 1 of 2
(731 Views)
1 REPLY 1
Re: Problems with Zencart installation on Plusnet
15-10-2009 7:23 PM
Hi
Is it on PAYH or PN CGI?
sounds like you're putting your images in the cgi-bin folder, am I right? they are being executed rather than viewed?
Message 2 of 2
(185 Views)
- Everything else
